Using JMP > JMP Reports > Customize Hover Labels in JMP Graphs > Right-Click Options for Hover Labels
Publication date: 02/06/2025
Background Color
Applies the selected color to the label background.
Frame Color
Applies the selected color to the label border and tag line.
Text Color
Applies the selected color to the text.
Filled
Applies the background color and frame color to the label. Selected by default.
Use Gradient
Shades the background color vertically from light to dark. Selected by default.
Font
Applies the selected font family to the text. The default font is determined by your JMP Font preferences.
If a script with a pinned label refers to a font that is not on the computer, the script does not run.
Add Text
Adds text to the bottom of the label.
Replace Text
Change the text on the tooltip. If you redo the analysis, the tooltip text remains updated.
Tag Line
Draws a line between the label and the data point. The Frame Color is applied to the line.
Copy
Copies the hover label contents to the clipboard.
Subset
Opens a data table with the subset data associated with the hover label.
Edit
Opens the Hover Label Editor, where you can further edit the contents of the hover label. See Edit Hover Labels in JMP Graphs.
Close
Removes the label. You can also remove the label by clicking the X in the upper right corner of the label.
Note: To return to the default label formatting, remove the label and add it again.
