Profilers > Contour Profiler > The Contour Profiler Report > Response Settings and Controls
Publication date: 02/06/2025
You can change the settings for the responses directly from the Contour Profiler report.
Response
The list of one or more responses, with a color legend. To change the color of a response, right-click the color legend for that response.
Contour
The current value of the contour on the contour profiler. Click in the box to change the value. The slider control can also be used to change the value of the contour.
Current Y
The predicted response based on the current X settings. The value is at the red line on the slider control. This value updates as the factor settings are changed.
Lo Limit
Enables you to set a lower limit for your response. Click in a box to set the limit or click the left triangle of the slider control for that response. If a response column’s Spec Limits column property has a value for Lower Spec Limit, that value is used as the initial value for Lo Limit.
High Limit
Enables you to set an upper limit for your response. Click in a box to set the limit or click the right triangle of the slider control for that response. If a response column’s Spec Limits column property has a value for Upper Spec Limit, that value is used as the initial value for Hi Limit.
When response limits are used, the profiler shows regions that are not feasible as shaded in the contour profiler plot.
Note: If your response has a Response Probability column property, the High Limit is automatically set to 0.5. In this case, the shaded region is the region where that response level is predicted.
