Using JMP > JMP Reports > Navigate JMP Reports > Resize a Report Window
Publication date: 02/06/2025
In JMP, report windows are automatically sized to fit the contents of the window. On Windows, you can automatically resize a window after manually resizing it. Press Ctrl and click the lower right corner of the window.
