Publication date: 02/06/2025
Report Options
Customize the appearance of the Categorical report using the following options:
Cross Tabulation Options
Frequencies
Shows or hides the frequency (labeled Freq) in the Crosstab table. The frequency is the count of the responses in each category.
Share of Responses
Shows or hides the share of responses (labeled Share) in the Crosstab table. The share of responses is the percent of responses in each category.
Rate Per Case
(Available only for multiple responses.) Shows or hides the rate per case (labeled Rate) in the Crosstab table. The rate per case is the percent of responses in each category based on the total number of cases (regardless of whether they were a respondent).
Rate per Case Responding
(Available only for multiple responses.) Shows or hides the Rate per Case Responding in the Crosstab table. The rate per case responding is the percent of responses in each category based on the cases that responded.
Chart Options
Share Chart
Shows or hides a divided bar chart. The bar length is proportional to the percentage of responses for each type. The column on the right shows the number of responses in each grouping category. If no grouping category is used, the column on the right shows the total number of responses.
Frequency Chart
Shows or hides a Frequency Chart. The bars reflect the frequency of responses within each group. The scale is consistent across the chart. The gray bars at the far right represent the total number of responses in each grouping category.
Transposed Freq Chart
Shows or hides a transposed Frequency Chart. The bars reflect the frequency of responses within each group. The responses are the rows, and the grouping levels are the columns in chart. The totals for each grouping level are represented by gray bars in the bottom row of the chart.
Tip: You can change the colors in the share chart using the Value Colors column property. See “Value Colors” in Using JMP.
Crosstab Viewing Options
Crosstab
Shows or hides the Crosstab table. The Crosstab table displays the response categories as column headings and the grouping levels (when used) as row labels. The upper left cell of the table shows the labels for the items in each cell of the table (Freq, Share, Rate, and Rate per Case Responding). If the report contains a transposed Crosstab table, this option also removes the transposed Crosstab table from the report.
Crosstab Transposed
Shows or hides a transposed Crosstab table. The transposed Crosstab table displays the response categories as row labels and the grouping levels (when used) as column headings. The upper left cell of the table shows the labels for the items in each cell of the table (Freq, Share, Rate, and Rate per Case Responding). If the report contains a Crosstab table, this option also removes the Crosstab table from the report.
