Publication date: 02/06/2025
Image shown hereRepairable Systems Simulation Platform Options
The Repairable Systems Simulation red triangle menu contains the following options:
Save and Save As
Enables you to save a Repairable Systems Simulation to a JMP Scripting Language (JSL) script that is automatically executed when it is opened in JMP. See “Advanced Note: Auto-Submit” in the Scripting Guide for more information about Auto-Submit scripts.
Note: The Save and Save As red triangle options are equivalent to selecting File > Save and File > Save As, respectively. They are available in the red triangle menu for convenience.
Import Component Distribution Settings
Enables you to import configuration settings for the system diagram from a data table. The table must contain columns for the component name, distribution, and one or more parameters. The number of parameters depends on the specified distribution.
Note: The strings in the imported table must be exact matches to the strings in the system diagram.
Export Component Distribution Settings
Enables you to export configuration settings for the system diagram to a data table. The table contains columns for the component name, distribution, and parameters. The parameters that are included depend on the specified distribution.
