Using JMP > JMP Reports > Reformat Tables in JMP Reports
Publication date: 02/06/2025
There are many ways to change the formatting of a JMP report table. Right-click a report table to access the following formatting options:
Table Style
Adds borders, shading, and dividing lines to the table. Select from the following options:
Underline Headings
Shows the preference setting for Underline Table Headings.
Shade Headings
Shows the preference setting for Shade Table Headings.
Heading Column Borders
Shows divider lines between columns in headings.
Column Borders
Contains borders outside columns and divider lines between columns.
Row Borders
Contains borders outside rows and divider lines between columns.
Shade Alternate Rows
Shades alternate rows.
Shade Cells
Shades the body of the table. When used with Shade Alternate Rows, a darker shade is used on alternate rows.
Note: Change the format of all report tables by selecting the preceding options in the JMP preferences. On Windows, the Report Tables options are in File > Preferences > Styles. On macOS, select the Report Tables options in JMP > Preferences > Styles.
Columns
Shows or hides columns in the table.
Note: Columns whose names begin with a tilde (~), such as ~Bias, are not applicable to the analysis that you ran and do not appear in the table, even if you place checks next to their names.
Sort by Column
Sorts the columns in descending or ascending order by the selected column. You can also select Numerical Order to sort a sorted string column numerically. After you do that, the Numerical Order option is available when you right-click the column. For more information about the sorting rules used by the Numerical Order option, see “Numerical Order”.
Make into Data Table
Creates a JMP data table from the report table. The data table script recreates the report and the data table generated by Make into Data Table.
Make Combined Data Table
Searches the report for other tables like the one you selected and combines them into a single data table. The data table contains a column that identifies the original data table. The data table script recreates the report and the data table generated by Make Combined Data Table.
Make Into Matrix
Creates a JMP matrix from a report table. See Change a Table in a JMP Report Into a Matrix.
Select Where
(Available only for categorical columns) Creates a Where clause using the selected columns or a complex expression.
Show Properties
Enables you to change the formatting of display boxes in the report.
Format Columns
Changes the numeric formatting of one or more columns in the table.
Copy Column
Copies the contents of the right-click column to the clipboard for pasting into another window or application.
Copy Table
Copies the right-click table to the clipboard for pasting into another window or application.
Simulate
Provides simulated results for the selected column of statistics in a report.
Image shown here Bootstrap
Approximates the sampling distribution of a statistic. See “Bootstrapping” in Basic Analysis.
