The Profiler red triangle menu contains the following options:
Profiler
Shows or hides the Prediction Profiler.
Contour Profiler
Shows or hides the Contour Profiler.
Custom Profiler
Shows or hides the Custom Profiler.
Surface Profiler
Shows or hides the Surface Profiler.
Mixture Profiler
Shows or hides the Mixture Profiler.
Show Formulas
Opens a JSL window showing a script for all formulas being profiled.
Formulas for OPTMODEL
Creates code for the OPTMODEL procedure in SAS. Press Ctrl+Shift and then select Formulas for OPTMODEL from the red triangle menu.
The following options are available in many platforms. See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, and “Save Script Menus in JMP Reports” in Using JMP.
Redo
Save Script
