The Print pages enables you to configure default print settings such as, margins, header, and footers.
Figure 15.27 Print Preferences
Preference | Description |
Top (margin) | Sets the print page’s top margin. The default setting is 0.75 inches. |
Left (margin) | Sets the print page’s left margin. The default setting is 0.75 inches. |
Right (margin) | Sets the print page’s right margin. The default setting is 0.75 inches. |
Bottom (margin) | Sets the print page’s bottom margin. The default setting is 0.75 inches. |
Left (header) | Sets the page’s left-side header information. The default setting is &wt; (that is, the title). |
Center (header) | Sets the page’s center header information. The default setting is blank. |
Right (header) | Sets the page’s right-side header information. The default setting is Page &pn; of &pc; (that is, Page # of count). |
Left (footer) | Sets the page’s left-side footer information. The default setting is blank. |
Center (footer) | Sets the page’s center footer information. The default setting is blank. |
Right (footer) | Sets the page’s right-side footer information. The default setting is blank. |
Orientation | Sets the page’s print orientation as either Portrait or Landscape. The default setting is Portrait. |
Scale Factor | Sets the page’s print scaling factor (in percent). The default setting is 100%. |
Table of Contents | Specifies whether to print a Table of Contents of your chosen file. The default setting is Never. When set to Conditionally, JMP will determine whether or not to print a Table of Contents based on the values of the following options: • Minimum number of pages • And/Or • Minimum number of outlines |
Note: The code for printing the current date in the header or footer is &d.
