Publication date: 02/06/2025
Preview JMP Files
For some JMP file types, you can use Windows Explorer or macOS Finder to view a portion of the selected file. Windows supports a preview of JMP data tables, journals, and scripts. macOS supports a preview of data tables and scripts.
To preview a JMP file
1. In Windows Explorer or the macOS Finder, select the file that you want to preview.
2. In Windows Explorer, select the Show the preview pane Image shown here button in the upper right corner. Support in e-mail programs varies.
In the macOS Finder, select the file and press the spacebar, or select the Quick Look option on the pop-up menu or File menu. In Mail, select the Quick Look Attachment option on the pop-up menu or File menu.
The preview pane shows a portion of the selected file.
Figure 2.17 Data Table Preview Pane (Windows)
