Using JMP > Platform Presets
Publication date: 02/06/2025
Platform Presets
Save and Reuse Report Customizations
The first analysis report applied to a data table is rarely the final report. JMP Platform Presets enable you to further configure a platform report as you like, save the results, and quickly reuse them on the same or another data table or set of columns.
This allows you to save a selection of red triangle menu options and open your report with the same configuration applied quickly and easily.
Figure 10.1 The Platform Preset menuĀ
Contents
Overview of Platform Presets
Example of Platform Presets
Build a Platform Preset
Platform Preset Menu Options
Customize the Available Presets Menus
Additional Examples of Platform Presets
