Using JMP > JMP Reports > Add Images to a JMP Graph or Report > Paste a Background Image into a JMP Graph
Publication date: 02/06/2025
1. Open the graphic file in a graphics program and select the graphic. Copy it to the computer’s clipboard.
2. Right-click inside a graph.
3. Select Edit > Paste Background Image. The graphic is inserted at the point in the graph that you right-clicked.
