Publication date: 02/06/2025
Parameter Estimates
In the Choice Model report, the Parameter Estimates section provides estimates and standard errors of the coefficients of utility associated with the effects listed in the Term column. The coefficients associated with attributes are sometimes referred to as part-worths. When the Firth Bias-Adjusted Estimates option is selected in the launch window, the parameter estimates are based on the Firth bias-corrected maximum likelihood estimators. These estimates considered to be more accurate than MLEs without bias correction. For more information about utility, see Utility and Probabilities.
Comparison Criteria
The AICc (corrected Akaike’s Information Criterion), BIC (Bayesian Information Criterion), 2Loglikelihood, and 2Firth Loglikelihood fit statistics are shown as part of the report and can be used to compare models. See “Likelihood, AICc, and BIC” in Fitting Linear Models.
The 2Firth Loglikelihood fit statistic is included in the report when the Firth Bias-Adjusted Estimates option is selected in the launch window. Note that this option is checked by default. The decision to use or not use the Firth Bias-Adjusted Estimates does not affect the AICc score or the 2Loglikelihood results.
Note: For each of these statistics, a smaller value indicates a better fit.
