Predictive and Specialized Modeling > Formula Depot > Overview of the Formula Depot Platform
Publication date: 02/06/2025
Image shown hereOverview of the Formula Depot Platform
The Formula Depot is a repository to organize, compare, profile, and score models for deployment. Models are prediction formulas. Prediction formulas are saved to the Formula Depot as column scripts. You can add prediction formulas to JMP tables to score data. You can also use the Formula Depot to generate scoring code for prediction formulas to facilitate the deployment of models in environments outside of JMP.
The Formula Depot enables you to perform the following tasks:
save prediction formulas outside of data tables
save prediction formulas from multiple data tables in a common location
save intermediate cleaning formulas within a prediction formula
compare models
profile models
add prediction formulas to a data table for scoring of new data within JMP
generate scoring code (C, Python, JavaScript, SAS, or SQL) for deploying models outside of JMP
The Formula Depot includes intermediate formulas in the generated scoring code. A model constructed from inputs with column formulas includes the corresponding formulas in the scoring code. For example, if your model includes a recoded variable the recode formula is included in the scoring code. This enables you to apply your prediction formula to raw data that has not been processed.
Note: Informative missing column formulas are not supported as intermediate formulas in the generated scoring code.
