Multivariate Methods > Cluster Variables > Overview of the Cluster Variables Platform
Publication date: 02/06/2025
The Cluster Variables platform constructs components that are linear combinations of variables into a cluster of similar variables. This differs from principal components analysis, which constructs components that are linear combinations of all the variables in the analysis. In the Cluster Variables platform, the entire set of variables is partitioned into clusters. For each cluster, a cluster component is constructed using the first principal component of the variables in that cluster. This cluster component is the linear combination that explains as much of the variation as possible among the variables in that cluster.
You can use the Cluster Variables option as a dimension-reduction method. A substantial part of the variation in a large set of variables can often be represented by cluster components or by the most representative variable in the cluster. These new variables can then be used in predictive or other modeling techniques. The new cluster-based variables are usually more interpretable than principal components based on all the variables.
Principal components constructed from a common set of variables are orthogonal. However, cluster components are not orthogonal because they are constructed from distinct sets of variables.
When you have a large set of variables, the Cluster Variables platform uses an algorithm based on the singular value decomposition to shorten computation time. For additional background, see “Wide Linear Methods and the Singular Value Decomposition”.
