Design of Experiments Guide > Custom Designs > Overview of Custom Design
Publication date: 02/06/2025
Use the Custom Design platform to construct an optimal design custom built for your specific experimental needs.
You can include a wide range of factor types, including the following:
Continuous
Discrete numeric (with any number of levels)
Categorical (with any number of levels)
Blocking (with a specified number of runs per block)
Covariate
Mixture
Constant
Uncontrolled
Specify the Region of Operability
You can restrict your experimental region to reflect your operating conditions using linear factor constraints or disallowed combinations. In particular, restrictions can be specified for categorical, continuous, and discrete numeric factors. See Define Factor Constraints.
Specify Factors with Hard-to-Change Levels
For continuous, discrete numeric, categorical, and mixture factors, you can indicate two levels of difficult-to-change factors. These difficulty levels are represented by whole plots or whole plots and split plots. You can also specify hard-to-change covariates.
Specify the Effects of Primary Interest
You can explicitly specify your assumed model. Your assumed model is an initial model that ideally contains all the effects that you want to estimate. Your model can contain any combination of main effects, interactions, response surface effects, and polynomial effects (up to the fifth power). You can specify the effects for which estimability is necessary and those for which estimability is desired. Custom Design uses a Bayesian optimality approach to estimate effects whose estimability is desired, subject to the number of runs. See Model.
Specify the Number of Runs
The Custom Design platform enables you to specify the number of runs that matches the budget for your experimental situation. The platform indicates the minimum number of runs that can be used to estimate the required effects and provides a default number of runs. These values can serve as a guide for determining a feasible number of runs. See Design Generation.
Construct the Appropriate Design Type
The Custom Design platform enables you to construct a wide variety of design types. These include classical designs and random block designs. For examples of different design types, see “Examples of Custom Designs”.
Construct an Optimal Design
Given your specific requirements, the Custom Design platform constructs a design that is optimal. The algorithm supports several optimality criteria:
D optimality
I optimality
Bayesian D and I optimality (using If Possible effects)
A optimality
Alias optimality
See Optimality Criteria.
Designs are constructed using the coordinate-exchange algorithm (Meyer and Nachtsheim, 1995). See Coordinate-Exchange Algorithm.
