Publication date: 02/06/2025
Open Files in a Project
In a JMP project, you can open data tables and then run analyses on the data. Each data table and analysis report opens in a new tab.
1. From a project window, select File > Open and browse to the data tables that you want in the project.
2. From a data table, run an analysis.
If a data table is updated on your computer, any associated reports in your project update when you reopen the project.
Figure 11.22 Initial Project
Initial Project
Tip: In JMP projects you can use common keyboard shortcuts, such as Ctrl+S to save a file, or Ctrl+W to close the active window. To see a list of all the keyboard shortcuts, install the Documentation Add-in from https://jmp.com/doc-addin and then select Help > Documentation PDFs > Keyboard Shortcuts.
