Design of Experiments Guide > Nonlinear Designs
Publication date: 02/06/2025
Nonlinear Designs
Use a nonlinear design for a response that is nonlinear in the unknown parameters. A nonlinear design places design points in areas that are key to fitting the nonlinear model. You could use an orthogonal design that is optimal for a linear model for a nonlinear response. However, such designs often do not place design points in locations that minimize the uncertainty or maximize the precision of the estimates of the fitted parameters.
The efficiency of a nonlinear design depends on the values of the unknown parameters. This creates a circular problem in that to find the best design, you need to know the parameters in advance. JMP uses a Bayesian approach to construct a nonlinear design that maximizes the average efficiency over specified ranges of the values of the parameter. To properly specify these ranges, you must have some insight about the system of interest.
Nonlinear designs offer these advantages compared to designs for linear models:
Predictions using a well-chosen model are likely to be good over a wider range of factor settings.
It is possible to model response surfaces with complex curvature and with asymptotic behavior.
Figure 23.1 Design Points for a Nonlinear Model
Contents
Overview of Nonlinear Designs
Example of a Nonlinear Designs
Build a Nonlinear Design
Factors
Parameters
Design Generation
Design
Make Table or Augment Table
Nonlinear Design Options
Additional Examples of Nonlinear Designs
Example of Augmenting a Nonlinear Design
Example of a Nonlinear Design for a Binomial Response
Statistical Details for Nonlinear Designs
Statistical Details for Nonlinear Models
Statistical Details of Radial-Spherical Integration of the Optimality Criterion
Statistical Details for Finding the Optimal Design
