Publication date: 02/06/2025
Image shown hereModel Screening
Fit and Compare Multiple Prediction Models
The Model Screening platform is available only in JMP Pro.
The Model Screening platform in JMP Pro enables you to run multiple predictive modeling platforms from one launch window and assemble summaries from the different methods. This helps you select the best performing model without launching each individual model platform. You can also easily launch an individual platform report for any of the models from the Model Screening report window for further refinement.
Figure 10.1 Model Screening ReportĀ
Contents
Example of Model Screening
Launch the Model Screening Platform
The Model Screening Report
Summary Across the Folds Report
Training, Validation, and Test Measures of Fit
Model Screening Platform Options
Decision Thresholds Report
