Publication date: 02/06/2025
Model Fit Report
A report is created for each individual model that is fit in the Fit Curve platform. Each model report contains the following sections.
Prediction Model
Shows the algebraic form of the prediction formula and the parameters.
Summary of Fit
Shows the same fit statistics as the Model Comparison report.
Group Summary
(Appears only if there is a grouping variable.) Shows the group estimates of the parameters.
Parameter Estimates
Shows the estimates of the parameters, standard errors, Chi-squared statistics, p-values, and confidence intervals. There are also separate tables for the correlations and covariances of the estimates.
Tip: You can sort the Parameter Estimates report table by clicking on the column that you want to sort by.
Plot
Shows plots of the data with the fitted model (Figure 14.7). The plots are shown only when you select a Grouping variable on the platform launch window.
