Predictive and Specialized Modeling > Matched Pairs Analysis
Publication date: 02/06/2025
Compare Measurements on the Same Subject
The Matched Pairs platform compares the means between two or more correlated variables and assesses the differences. For example, you might compare a blood pressure measurement taken on the same subject before a treatment and again after the treatment. A statistical method called the paired t test takes the correlated responses into account.
The platform produces a graph of the paired differences by the paired means, and the paired t test results for all three alternative hypotheses. Additional features provide for more than two matched responses and for a grouping column to test across samples, in a simple version of repeated measures analysis.
Figure 20.1 Example of Matched Pairs Analysis
Contents
Overview of the Matched Pairs Platform
Example of Comparing Matched Pairs
Launch the Matched Pairs Platform
Multiple Y Columns
The Matched Pairs Report
Difference Plot and Report
Across Groups
Matched Pairs Platform Options
Example Comparing Matched Pairs across Groups
Statistical Details for the Matched Pairs Platform
Statistical Details for Graphics of Matched Pairs
Statistical Details for the Correlation of Responses
