Predictive and Specialized Modeling > Make Validation Column
Publication date: 02/06/2025
Image shown hereMake Validation Column
Divide Data into Training, Validation, and Test Sets
The Make Validation Column platform is available only in JMP Pro.
Validation is the process of using part of a data set to estimate model parameters and using another part to assess the predictive ability of a model. You can partition the data into two or three sets or create four or more categories for K-Fold crossvalidation. The Make Validation Column platform provides several methods to create these partitions.
Contents
Overview of the Make Validation Column Platform
Example of the Make Validation Column Platform
Launch the Make Validation Column Platform
Make Validation Column Report
Specify Rates or Relative Rates
Set Cutpoints
Set Number of Folds
Options
Go
Make Validation Column Platform Options
Additional Example of the Make Validation Column Platform
