Mac OS Settings preferences customize settings for macOS machines, including the graphics formats and file associations.
Figure 15.24 Mac OS Settings Preferences
Preference | Description |
Alternate Image Formats for Clipboard and Drag & Drop | Select one or more graphic formats to use when copying and pasting (or dragging and dropping) graphics from JMP into other applications. The default setting is TIFF. |
Clipboard Image Scale Factor | Enter the percentage at which you want graphics to appear in other applications. The default setting is 200%. |
Image format for RTF | Select the format to use for graphics when you save a JMP report as an RTF file. The default setting is PNG. |
RTF Image Scale Factor | Enter the percentage at which you want graphics to appear in RTF documents. The default setting is 100%. |
Image format for HTML | Select the format to use for graphics when you save a JMP report as an HTML file. The default setting is PNG. |
Locale Format Settings | Specify the decimal and thousands separators used for numbers and currency values. The Default setting uses the system locale. If a non-default setting is specified, that setting overrides the system locale. |
