Reliability and Survival Methods > Life Distribution > Life Distribution Report Options
Publication date: 02/06/2025
The Life Distribution red triangle menu contains the following options:
Fit All Distributions
Fits all distributions other than the threshold (TH) distributions. The distributions are compared in the Model Comparisons report. See Compare Distributions in Life Distribution.
Tip: Select the Comparison Criterion option to change the criterion for finding the best distribution.
Fit All Nonnegative
Fits all nonnegative distributions (Exponential, Lognormal, Loglogistic, Fréchet, Weibull, and Generalized Gamma). The distributions are compared in the Model Comparisons report. See Compare Distributions in Life Distribution. Note the following:
The option does not fit DS or TH distributions.
If the data have negative values, then the option produces no results.
If the data have zeros, the option fits the four zero-inflated (ZI) distributions: ZI Lognormal, ZI Weibull, ZI Loglogistic, and ZI Fréchet. For more information about zero-inflated distributions, see Zero-Inflated Distributions.
Fit All DS Distributions
Fits all defective subpopulation (DS) distributions: DS Lognormal, DS Weibull, DS Loglogistic, and DS Fréchet. For more information about defective subpopulation distributions, see Distributions for Defective Subpopulations.
Fit Mixture
Fits a distribution that is a mixture of the distributions other than the threshold (TH) distributions. See Fit Mixture.
Fit Competing Risk Mixture
Fits a competing risk mixture distribution to the data. See Fit Competing Risk Mixture.
Nonparametric Estimate Plot Options
A submenu of options for how data is displayed on the probability plot.
Points
Shows the midpoint estimates of the Kaplan-Meier step function in the probability plot. The Points option is selected by default.
Step Function
Shows the Kaplan-Meier estimates in the probability plot.
Both
Shows both the midpoint estimates and the Kaplan-Meier estimates in the probability plot.
None
Hides the midpoint estimates and the Kaplan-Meier estimates in the probability plot.
Show Event Plot Frequency Label
(Appears only if you have specified a Freq variable.) Shows or hides the Frequency label in the Event Plot.
Show Survival Curve
Switches between the failure probability and the survival curve on the Compare Distributions probability plot and the Distribution Profiler plots.
Show Quantile Functions
Shows or hides a Quantile Profiler that overlays the plots for the selected distributions. The Quantile plot also shows points plotted at time values. The plot appears beneath the Compare Distributions report. If you select distributions in any of the Compare Distributions, Quantile Profiler, and Hazard Profiler plots, they appear in the other two plots.
Show Hazard Functions
Shows or hides a Hazard Profiler that overlays the plots for the selected distributions. The plot appears above the Statistics report. If you select distributions in any of the Compare Distributions, Quantile Profiler, and Hazard Profiler plots, they appear in the other two plots.
Show Statistics
Shows or hides the Statistics report. See Statistics for Life Distribution.
Tabbed Report
Shows graphs and data on individual tabs rather than in the default outline style.
Show Confidence Area
Shows or hides the shaded confidence regions in the plots.
Interval Type
Determines the type of confidence interval shown for the Nonparametric fit in the Compare Distributions plot. Select either pointwise or simultaneous confidence intervals.
Change Confidence Level
Enables you to change the confidence level for the entire platform. All plots and reports update accordingly.
Enables you to select the criterion used to rank models in the Model Comparison report. For all four criteria, smaller values indicate better fit. Burnham and Anderson (2002) and Akaike (1974) discuss using AIC, AICc, and BIC for model selection. See “Likelihood, AICc, and BIC” in Fitting Linear Models.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
If you have specified a By variable, separate Life Distribution reports appear for each level of the By variable.
Save By Group Results
For each By group, saves the estimates that appear in all Parametric Estimate reports for that group as a separate row in a new table.
Do Same Analyses for All Groups
Applies all of the selected options for the current group to all other By groups.
