Multivariate Methods > Latent Class Analysis > Latent Class Analysis Platform Options
Publication date: 02/06/2025
The Latent Class Analysis red triangle menu contains the following options:
New Number of Clusters
Enables you to run another analysis using a different number of clusters. The new analysis report is appended to the current report.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Save Platform Preferences”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
