Scripting Guide > Python > Python Syntax Reference > jmp Package Functions
Publication date: 02/06/2025
jmp.current()
Returns a DataTable object for the current JMP data table.
jmp.open('file_path')
Description
Opens the file located at 'file_path'.
Returns
If the file is a JMP file or a file that imports into a JMP data table, the object returned will be a DataTable object. Otherwise, jmp.open() will return True or False for success or failure.
Argument
'file_path'
The file path of the file to be opened.
jmp.run_jsl('JSL_script')
Description
Runs the provided JSL script from within the Python environment, including JSL’s Python interface functions.
Argument
'JSL_script'
A provided JSL script.
jmp.table('table_name')
Description
Returns a jmp.DataTable object for the opened table 'table_name'.
Returns
Returns the value of the named variable.
Argument
'table_name'
The name of the JMP data table to be returned.
