Discovering JMP > Introducing JMP > JMP Concepts That You Should Know
Publication date: 02/06/2025
Before you begin using JMP, you should be familiar with these concepts:
Enter, view, edit, and manipulate data using JMP data tables.
Select a platform from the Analyze, Graph, or DOE menus. Platforms contain interactive windows that you use to analyze data and work with graphs.
Platforms use these windows:
Launch windows where you set up and run your analysis.
Report windows showing the output of your analysis.
Report windows normally contain the following items:
A graph of some type (such as a scatterplot or a chart).
Specific reports that you can show or hide using the disclosure iconImage shown here.
Platform options that are located within red triangle menus Image shown here.
