Publication date: 02/06/2025
Import Customizations
Changes to toolbars and menus are stored in customization sets, or plain text files. You open a customization set in JMP to import your modified toolbars and menus. The customizations are then shown in the Menu Editor. See Customization Set Options for more information about the menu customization files.
To import customizations, follow these steps:
1. Select File > Open.
2. In the File name list, select All JMP Files (or JMP Menu Files) and then select the customization set.
3. Click Open.
A confirmation is displayed, stating that the customizations have been imported. The Menu Editor is also opened.
4. Display the Menu Editor and click OK to save the changes, or click Cancel to discard them.
