Publication date: 02/06/2025
Hide Columns in Data Tables
When your data table contains columns that you do not want to see in the data grid, you can hide those columns. Note the following:
Hidden columns appear in launch windows and are available for analyses.
A mask icon (Image shown here) appears to the right of the column name in the Columns panel.
To hide columns
1. Select one or more columns that you want to hide.
2. Do one of the following:
Right-click the highlighted column name in the Columns panel and select Hide/Unhide.
From the Cols menu, select Hide/Unhide.
To unhide columns
1. Select the columns in the Columns panel.
