Publication date: 02/06/2025
Hide a Data Table
Using JSL, there are two ways to hide a data table if the user does not need to see the table: by opening it as invisible or private.
Invisible Data Tables
An invisible data table is hidden from view but linked to analyses that you run on it. Open a data table as an invisible file:
dt = Open( "$SAMPLE_DATA/Big Class.jmp", "invisible" );
Here is an example of creating an invisible table, called Abc, that has ten rows. One column is named X.
dt = New Table( "Abc", "invisible", New Column( "X" ), Add Rows( 10 ) );
To find out if an open data table is invisible, pass the Boolean Has Data View message to the data table object. The following expression returns 0 (false) if the data table is invisible:
dt << Has Data View();
After you are finished with an invisible data table, do not forget to close it with the Close() function. Otherwise, the data table remains in memory until you quit JMP.
Showing an Invisible Data Table
The Show Window() function shows an invisible data table.
dt << Show Window( 1 );
The user has the option of opening the table from the JMP interface. On Windows, an invisible data table appears in the Window List on the Home Window and the Window > Unhide menu. On macOS, the data table appears in the JMP Home window and the Window > Hidden menu.
Private Data Tables
Completely hide the data table from view by including the private argument:
dt = Open( "$SAMPLE_DATA/Big Class.jmp", "private" );
A private data table enables you to avoid exposing the table to general use. Sometimes a script creates a private data table to store private data generated by a process. It is not for saving memory.
See Private, Invisible, and Visible.
