Design of Experiments Guide > Group Orthogonal Supersaturated Designs
Publication date: 02/06/2025
Create Group Orthogonal Supersaturated Designs
Group orthogonal supersaturated designs are a special case of screening designs. They are appropriate in early stage work when the number of factors to be investigated is larger than the number of feasible runs. A supersaturated design is a design with fewer observations than model parameters. That is, the design cannot estimate all main effects simultaneously. This makes detection of significant effects difficult. A group orthogonal supersaturated design is a special class of two-level supersaturated designs with properties that are desirable for model selection.
Contents
Overview of Group Orthogonal Supersaturated Designs
Example of Group Orthogonal Supersaturated Designs
Build a Group Orthogonal Supersaturated Design
Specify Factors, Structure, and Make Design
Verify Design and Make Table
Group Orthogonal Supersaturated Design Options
Statistical Details for Group Orthogonal Supersaturated Designs
