Discovering JMP > Work with Your Data > Get Your Data into JMP
Publication date: 02/06/2025
JMP provides many ways to get your data into JMP, from copying to importing data to entering data directly.
To copy and paste data from another application, see Copy and Paste Data into a Data Table.
To import data from another application, see Import Data into a Data Table.
To enter data directly into a data table, see Enter Data in a Data Table
You can also import data into JMP from a database. See “Import Data from a Database” in Using JMP.
This chapter uses sample data tables and sample import data that is installed with JMP. To find these files, see “Using Sample Data”.
