Publication date: 02/06/2025
Image shown hereFormula Depot Model Options
Each prediction formula that is saved in the Formula Depot has an individual options menu. In addition to Show, Copy, Run, and Code Generation options that correspond to the main menu options, the individual menus include the following options:
Rename New Column
Enables you to rename the model. This new name is applied as the column name if you run the script to add the prediction formula to a JMP data table. In addition, this name is included in generated code.
Remove
Removes the model from the Formula Depot. This command cannot be undone.
