Reliability and Survival Methods > Fit Parametric Survival
Publication date: 02/06/2025
Fit Survival Data Using Regression Models
Survival times can be expressed as a function of one or more variables. When this is the case, fit a linear regression model that takes into account the survival distribution and censoring. The Fit Parametric Survival platform fits the time to event Y (with censoring) using linear regression models that can involve both location and scale effects. The fit is performed using the Weibull, lognormal, exponential, Fréchet, loglogistic, smallest extreme value (SEV), normal, largest extreme value (LEV), and logistic distributions.
Note: The Fit Parametric Survival platform is a slightly customized version of the Fit Model platform. You can also fit parametric survival models using the Nonlinear platform.
Figure 15.1 Example of a Parametric Survival Fit
Contents
Overview of the Fit Parametric Survival Platform
Example of the Fit Parametric Survival Platform
Launch the Fit Parametric Survival Platform
The Parametric Survival Fit Report
The Parametric Survival - All Distributions Report
Parametric Competing Cause Report
Fit Parametric Survival Options
Nonlinear Parametric Survival Models
Additional Examples of Fitting Parametric Survival
Example of an Arrhenius Accelerated Failure Lognormal Model
Example of an Interval-Censored Accelerated Failure Time Model
Example of Analyzing Left-Censored Data
Statistical Details for the Fit Parametric Survival Platform
