Design of Experiments Guide > The Fit Definitive Screening Platform > Fit Definitive Screening Platform Options
Publication date: 02/06/2025
The Fit Definitive Screening Design red triangle menu contains the following options:
Set Stage 1 p value
Set the p-value threshold used for Stage 1. See Stage 1 Methodology.
Set Stage 2 ratio
Specify the ratio of the Stage 2 MSE to the Stage 1 MSE. See Stage 2 Methodology.
See “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Redo
Platform Preferences
Save Script
