Scripting Guide > Programming Methods > File and Directory Operations
Publication date: 02/06/2025
Pick Directory() and Pick File() enable the user to select a file or directory when the JSL script is run. To get a list of files in a directory, use Files In Directory().
Select a Directory or File
Get a List of Filenames
Connect to a Network Directory
