Publication date: 02/06/2025
Expression Functions
Arg(expr, i)
Arg Expr(expr, i)
Description
Finds the argument numbered by i within the given expression.
Returns
The ith argument within the expression expr.
Empty() if that argument does not exist or is not specified.
Arguments
expr
An expression.
i
An integer that indicates which argument to return.
Notes
Arg Expr() is deprecated. Use Arg() instead.
Eval Expr(expr)
Description
Evaluates any expressions within expr, but leaves the outer expression unevaluated.
Returns
An expression with all the expressions inside expr evaluated.
Argument
expr
A valid expression.
Expr(expr, i)
Description
Returns the argument unevaluated (expression-quoting).
Returns
The argument, unevaluated.
Argument
expr
An expression.
i
Extract Expr(expr, pattern)
Description
Find expr matching pattern.
Returns
A pattern that matches the specified pattern.
Arguments
expr
An expression.
pattern
Any pattern.
Head(exprArg)
Head Expr(exprArg)
Description
Returns the head of the evaluated expression, without its arguments.
Notes
Head Expr() is deprecated. Use Head() instead.
Head Name(expr)
Head Name Expr(expr)
Description
Returns the head of the evaluated expression as a quoted string.
Notes
Head Name Expr() is deprecated. Use Head Name() instead.
N Arg(exprArg)
Description
Returns the number of arguments of the evaluated expression head.
N Arg Expr(exprArg)
Description
Returns the number of arguments of the expression head.
Notes
N Arg Expr() is deprecated. Use N Arg() instead.
Name Expr(x)
Description
Returns the unevaluated expression of x rather than the evaluation of x.
