You can make the same plots shown in the example above using Graph Builder
1. Select Help > Sample Data Folder and open Students.jmp.
3. Select age, sex, height, and weight, hold down the Shift key, and then click the X zone.
Figure 6.4 Adding Variables to the X Zone
Figure 6.5 Adding Variables to the Y Zone
Figure 6.6 Scatterplot Matrix in Graph Builder
