Design of Experiments Guide > Starting Out with DOE > Example of a Designed Experiment
Publication date: 02/06/2025
The following example uses DOE to examine the strength of brewed coffee. A less complex treatment of this example using the Easy DOE platform is described in “Example of the Easy DOE Platform”.
Define the Study and Goals
Create the Design
Run the Experiment
Analyze the Data
