Publication date: 02/06/2025
Edit Items
You can perform the following tasks for items:
Note: The items associated with JMP provided common orderings cannot be changed.
Add items to new and existing common orderings. In the field below the items box, type one item at a time and click Add Image shown here.
Change the order of the items. Use the arrows to move the items and change the order in which they appear.
Delete an item. To delete an item, click Delete Image shown here.
Specify an exact match. Use the Exact Match option to indicate that the items must be identical. If this option is deselected, case and whitespace can be different.
