Using JMP > JMP Reports > Customize Common Orderings > Edit Common Orderings
Publication date: 02/06/2025
You can perform the following tasks for user-created common orderings:
Create a new common ordering. In the field below the Common Orderings box, type a name for the ordering and click Add Image shown here.
Duplicate a common ordering. Select the ordering and clicking Duplicate. JMP provided orderings can be duplicated and then changed.
Delete a common ordering. To delete an ordering, click Delete Image shown here.
Arrange orderings. If you have similar orderings, use the arrows to arrange them by order or importance. JMP will apply the orderings in the order in which they appear in the list.
