Publication date: 02/06/2025
Degradation
Model Product Deterioration over Time
Use the Degradation platform to analyze degradation data and produce pseudo failure times. These pseudo failure times can then be analyzed by other reliability platforms to estimate failure distributions.
Both linear and nonlinear degradation paths can be modeled. You can specify an accelerating factor to analyze accelerated degradation data.
You can also perform stability analysis, which is useful when setting pharmaceutical product expiration dates.
Figure 16.1 Degradation Analysis Example
Contents
Overview of the Degradation Platform
Example of the Degradation Platform
Launch the Degradation Platform
The Degradation Platform Reports
Model Specification
Simple Linear Path
Nonlinear Path
Inverse Prediction
Prediction Graph
Degradation Platform Options
Degradation Model Summary Reports
Model List
Reports
Custom Destructive Degradation Models
Stability Analysis in the Degradation Platform
Statistical Details for Stability Analysis in the Degradation Platform
