Scripting Guide > Python > Python Syntax Reference > Data Table Functions
Publication date: 02/06/2025
dt = jmp.DataTable(name='string', rows=n)
Description
Creates a new data table with the name 'string' and n number of rows. The arguments are optional. If they are specified, they must be in the order: name, row. If the arguments are not specified in that order, the keywords name= and rows= must be used.
dt.add_rows(rows=n, after=m)
Description
Inserts n number of rows after row m. The after argument is optional.
dt.name = 'new name'
Description
Sets the data table’s name as the string 'new name'.
dt.new_column(name='string', dtype='string', mtype='string', dlen='string', where=n)
Description
Creates a new column object in the data table. All arguments are optional. Passing no arguments to dt.new_column() creates a default new column after the last column of the current data table with a numeric data type and a Continuous modeling type.
Arguments
name
Specifies the name of the new column.
dtype
Specifies the data type of the new column using the jmp.DataType enumeration values.
mtype
Specifies the modeling type of the new column using the jmp.ModelingType enumeration values.
dlen
Specifies the data length of columns with the Numeric data type.
where
Specifies the placement of the new column.
dt.save(path='file_path')
Description
Saves the data table to the specified file path or the current directory of the script if no path is specified.
dt.close(save=True|False)
Description
Closes the data table. The save argument is optional, and data tables are saved before closing if the argument is omitted. Setting the save argument to False closes the data table without saving.
