Publication date: 02/06/2025
Data Filter Messages
dtf<<Add Favorites(name)
Description
Associates the current filter selection with the quoted "name" and saves it in the Favorites list.
Returns
The favorite as a quoted string.
Example
df = dt << Data Filter(
	Add Filter(
		Columns( :age, :sex, :height, :weight ),
		Where( :sex == "F" ),
		Where( :height >= 55 & :height <= 65 )
	Mode( Select (1) )
Wait( 1 ); // for demonstration purposes
fav1 = df << Add Favorites( "Female Average Ht" );
dtf<<Add Filter(Columns(column1, <column2>), <Where(clause)>)
Add one or more filter columns in a new OR group.
dtf<<Auto Clear(Boolean)
Clears all currently selected rows before setting a new selection.
dtf<<Clear
Clears the currently selected rows.
dtf<<Close
Closes the data filter window.
dtf<<Columns(column1, column2, ...)
Sets the columns to use in the data filter.
dtf<<Data Table Window
Shows the data table that the data filter window is using.
dtf<<Delete All
Removes all filters that are set.
dtf<<Delete(column1, column2, ...)
Removes the specified columns from the data filter.
dtf<<Display(column, <Size(x, y)>, "Blocks Display"|"List Display"|"Single Category Display"|"Checkbox Display")
Sets how the specified categorical column levels are displayed in the filter.
dtf<<Get Script
Returns the data filter script as text in the log.
Example
     Add Filter( Columns( :age, :sex ), Where( :age == 12 ) )
txt = df << Get Script;
Show( txt );
dtf<<Local Data Filter
Embeds the data filter in the specified window. See “Add a Local Data Filter” in the Scripting Guide for more information about local data filters.
dtf<<Location(x, y)
Moves the data filter window to the specified location. x and y are measured in pixels. 0,0 is the top left of the monitor.
dtf<<Make Filter Change Handler(function)
Creates a data filter handler to handle notification that the filter has changed. The number of rows filtered is returned in the argument to the function.
Example
dt = Open( "$SAMPLE_DATA/PopAgeGroupSubset.jmp" );
dist = Distribution( Automatic Recalc( 1 ), Continuous Distribution( Column( :POP ) ) );
filter = dist << Local Data Filter( Add Filter( Columns( :Region ) ) );
f = Function( {a}, Print( a ) );
rs = filter << Make Filter Change Handler( f );
dtf<<Make Subset
Creates a new subset data table that contains the rows that are selected in the data filter.
dtf<<Match(Filter Columns(column1, column2, ...), Where(clause)
Sets the filter conditions for each column. The Where clause is used for all the columns listed. To use different Where clauses for different columns, send the Match message separately for each column.
dtf<<Mode(Select(Boolean)|Show(Boolean)|Include(Boolean))
Sets the action, or mode, that is used when rows are selected using the data filter.
dtf<<Save and Restore Current Row States
Saves the current row states for the data table, and then restores those states when the data filter is closed.
dtf<<Show Columns Selector(Boolean)
Displays or hides the column selector after completing a filter.
dtf<<To Clipboard
Creates a Where clause from the current state of the data filter and places it on the clipboard, where it can be pasted elsewhere.
dtf<<To Data Table
Creates a Where clause from the current state of the data filter and saves it as a property to the data table.
dtf<<To Journal
Creates a Where clause from the current state of the data filter and appends it to the current journal. If there is no current journal, a new journal is opened and the Where clause is added to it.
dtf<<To Row State Column
Creates a row state column whose formula is the Where clause.
dtf<<To Script Window
Creates a Where clause from the current state of the data filter and appends it to the current script window. If there is no current script window, a new script window is opened and the Where clause is added to it.
dtf<<Use Floating Window(Boolean)
Sets whether the data filter window floats on top of its associated data table or behaves as a normal window.
dtf<<Where(clause)
Sets a condition for selecting rows.
