Using JMP > JMP Technical Details > Conventions for Mapping JMP Attributes to SAS Extended Attributes
Publication date: 02/06/2025
SAS extended attributes are metadata that you define in SAS code to import information such as table scripts, labels, length, and type. You associate the extended attributes with a data set or variable and define them in name-value pairs, such as _JMP_TABLESCRIPTNAME_2="OnOpen".
This section provides information about SAS extended attributes and their corresponding JMP attributes.
Table B.1 Table Attributes
JMP Table Attribute
SAS Attribute Name
SAS Attribute Type and Default Value
Description
Table Variable Count
_JMP_TABLEVARCOUNT
Numeric, 0
Count of table variables
Table Variable Name 1
_JMP_TABLEVARNAME_1
String
Name of the first table variable
Table Variable Value 1
_JMP_TABLEVARVALUE_1
String
Value of the first table variable
Table Variable Name 2
_JMP_TABLEVARNAME_2
String
Name of the second table variable
Table Variable Value 2
_JMP_TABLEVARVALUE_2
String
Value of the second table variable
Table Variable Name n
_JMP_TABLEVARNAME_n
String
Name of the nth table variable
Table Variable Value n
_JMP_TABLEVARVALUE_n
String
Value of the nth table variable
Table Script Count
_JMP_TABLESCRIPTCOUNT
Numeric
Count of table scripts
Table Script Name 1
_JMP_TABLESCRIPTNAME_1
String
Name of the first table scripts
Table Script Value 1
_JMP_TABLESCRIPTVALUE_1
String
Value of the first table scripts
Table Script Name 2
String
Name of the second table script
Table Script Value 2
_JMP_TABLESCRIPTVALUE_2
String
Value of the second table script
Table Script Name n
_JMP_TABLESCRIPTNAME_n
String
Name of the table script n
Table Script Value n
_JMP_TABLESCRIPTVALUE_n
String
Value of table script n
Lock Data Table
_JMP_ISLOCKED
Boolean, 0
Locked table
Suppress Formula Eval
_JMP_SUPPRESSEVAL
Boolean, 0
Suppressed formula evaluation
Column Group Count
_JMP_COLGRPCOUNT
Numeric, 0
Number of column groups
Column Group Name 1
_JMP_COLGRPNAME_1
String
Name of column group 1
Column Group Start Col 1
_JMP_COLGRPSTARTCOL_1
String
Name of first column in group 1
Column Group NCols 1
_JMP_COLGRPNCOLS_1
Numeric
Number of columns in group 1
Column Group Name 2
_JMP_COLGRPNAME_2
String
Name of column group 2
Column Group Start Col 2
_JMP_COLGRPSTARTCOL_2
String
Name of first column in group 2
Column Group NCols 2
_JMP_COLGRPNCOLS_2
Numeric
Number of columns in group 2
Column Group Name n
_JMP_COLGRPNAME_n
String
Name of column group n
Column Group Start Col n
_JMP_COLGRPSTARTCOL_n
String
Name of first column in group n
Column Group NCols n
_JMP_COLGRPNCOLS_n
Numeric
Number of columns in group n
Table B.2 Column Attributes
JMP Column Attribute
SAS Attribute Name
Description
Column Name
_JMP_COLNAME
String
Original column name in JMP
Data Length
_JMP_DATALENGTH
Numeric, 0
Length of the data. For numeric types, the value can be 1, 2, 4, or 8. For character types, 0 (or negative) means variable length, positive values mean fixed-length.
Row State column
_JMP_ISROWSTATE
Numeric, 0
0 = not row state, 1 = default row state for table, 2 = row state column
Label
_JMP_ISLABEL
Boolean, 0
Label column. 1 for yes. 0 for no.
Scroll Lock
_JMP_ISSCROLLLOCK
Boolean, 0
Scroll locked column. 1 for yes. 0 for no.
Hidden
_JMP_ISHIDDEN
Boolean, 0
Hidden column. 1 for yes. 0 for no
Excluded
_JMP_ISEXCLUDED
Boolean, 0
Excluded column. 1 for yes. 0 for no
Notes
_SAS_NOTES
String
Notes about the column
Modeling Type
_SAS_LEVEL
String
Valid values are Binary, Interval, Ordinal, Nominal, Unary. JMP maps Binary and Unary to Nominal and Interval to Continuous.
Preselect Role
_SAS_MININGROLE
String
Valid values are Assessment, Censor, Classification, Cost, Cross ID, Decision, Frequency, ID, Input, Key, Label, Prediction, Referrer, Rejected, Residual, Segment, Sequence, Target, Text, Text Location, Time ID, Treatment, Web Address, Weight. JMP maps Y to Target, X to Input, Freq to Frequency, and Weight to Weight.
Distribution
_SAS_DISTRIBUTION
String
Distribution type to fit for this column
Format Name
_JMP_FORMATNAME
String
Format of the column (such as Fixed Dec or Percent)
Format Width
_JMP_FORMATWIDTH
Numeric
Width of the column
Format Decimals
_JMP_FORMATDECIMALS
Numeric
Number of decimal places
Format Code
_JMP_FORMATCODE
String
Typically the currency code for currency formats
Use Thousands Separator
_JMP_USETHOUSANDSSEP
Boolean, 0
Include thousands separator. 1 for yes. 0 for no.
Input Format
_JMP_INFORMAT
String
Input format (for date, time, or duration-formatted columns)
Formula
_JMP_FORMULA
String
Column formula
_JMP_SUPPRESSEVAL
Boolean, 0
Suppressed formula evaluation. 1 for yes. 0 for no.
Lock
_JMP_ISLOCKED
Boolean, 0
Locked column. 1 for yes. 0 for no.
Range Check Code
_JMP_RANGECHECK_CODE
String
A code that identifies the type of range check. Examples are LE, LT, LTLT, !LT, and !LELE.
Range Check Low
_JMP_RANGECHECK_LOW
Numeric
First argument to range check
Range Check High
_JMP_RANGECHECK_HIGH
Numeric
Second optional argument to range check
List Check
_JMP_LISTCHECK
String
List check
Missing Value Codes
_JMP_MISSINGCODES
String
Values to be treated as missing
Value Label Count
_JMP_VALUELABEL_COUNT
Numeric
Count of value labels
Value Label Code
_JMP_VALUELABELCODE_1
String
Code for the value label (such as EQ, LT, LE, LTLT, and LELT.). Always EQ for character variables.
Value Label Lower Bound
_JMP_VALUELABELLOW_1
Varies
The lower bound of a numeric range, or the only bound if the ranges is unbounded on one side. A string for character columns. Numeric for numeric columns.
Value Label Upper Bound
_JMP_VALUELABELHIGH_1
Numeric
The upper bound of a numeric range. Not used for character value labels.
Value Label Display
_JMP_VALUELABELDISPLAY_1
String
The display string for this value label
Use Value Labels
_JMP_USEVALUELABELS
Boolean, 0
Uses value labels when displaying this column. 1 for yes. 0 for no.
Value Scores
_JMP_VALUESCORES
String
Associates data values with numerical scores
Value Order
_JMP_VALUEORDER
String
The order of values for the column
Value Colors
_JMP_VALUECOLORS
String
Maps values to colors.
Color Gradient
_JMP_COLORGRADIENT
String
Maps values to a color gradient.
Color Cells
_JMP_COLORCELLS
Boolean, 0
Color cells of this column using the specified value colors or color gradient. 1 for yes. 0 for no.
Axis
_JMP_AXIS
String
Axis definition
Coding
_JMP_CODING
String
Code a range of values to -1, 1 for modeling purposes
Mixture
_JMP_MIXTURE
String
Participation in a mixture of columns adding up to a value. The Mixture column property has numeric values (limits) and string values (L Pseudo Component and U Pseudo Component).
Row Order Levels
_JMP_ROWORDER
Boolean, 0
Sort the column by occurrence rather than value. 1 for yes. 0 for no.
Spec Limits
_JMP_SPECLIMITS
String
Target value and upper and lower spec limits
Control Limits
_JMP_CONTROLLIMITS
String
Control limits for control chart type
Response Limits
_JMP_RESPONSELIMITS
String
Bounds on response’s acceptable range, used by profilers
Design Role
_JMP_DESIGNROLE
String
Role in a designed experiment
Factor Changes
_JMP_FACTORCHANGES
String
Difficulty of changing a factor, for DOE. Value values: Easy, Hard, Very Hard
Sigma
_JMP_SIGMA
String
Sigma for Control Charts
Units
_JMP_UNITS
String
Units for this variable; can be any string
Time Frequency
_JMP_TIMEFREQ
String
Numeric, Annual, Quarterly, Monthly, Weekly, Daily, Hourly, By Minutes, By Seconds
Map Role
_JMP_MAPROLE
String
Role in a map data set
Multiple Response Separator
_JMP_MRSEP
String, ","
Separator for a multiple-response column.
Label Column
_JMP_LABELCOLUMN
Boolean, 0
Is this column a label column? 1 for yes. 0 for no.
Expression Column
_JMP_ISEXPRESSIONCOLUMN
Boolean, 0
Is this column an expression column? 1 for yes. 0 for no.
Table B.3 Custom Column Properties
SAS Attribute Name
Description
Custom Property Count
_JMP_CUSTCOLPROPCOUNT
Numeric, 0
Count of custom column property
Custom Property Name 1
_JMP_CUSTCOLPROPNAME_1
String
Name of the custom column property 1
Custom Property Value 1
_JMP_CUSTCOLPROPVALUE_1
String
Value of the custom column property 1
Custom Property Name 2
_JMP_CUSTCOLPROPNAME_2
String
Name of the custom column property 2
Custom Property Value 2
_JMP_CUSTCOLPROPVALUE_2
String
Value of the custom column property 2
Custom Property Name n
_JMP_CUSTCOLPROPNAME_n
String
Name of the custom column property n
Custom Property Value n
_JMP_CUSTCOLPROPVALUE_n
String
Value of the custom column property n
