You can use JSL to create control charts, customize tests, run alarm scripts, and more.
If you add a custom reference line to a Control Chart Builder chart through JSL, the reference line label must be something other than “LSL”, “USL”, or “AVG”. These names are keywords used by the Control Chart Builder platform.
The following example creates custom reference lines with unique labels.
obj = dt << Control Chart Builder(
Variables( Y( :height ) ),
SendToReport(
Dispatch(
"height",
ScaleBox,
{Add Ref Line( 70, "Solid", "Black", "Upper Limit", 1 ),
Add Ref Line( 55, "Solid", "Black", "Lower Limit", 1 )}
You can design custom tests and select or deselect multiple tests at once using the Customize Tests function. You specify the description, desired number, and label. This option is available only for Variables and Attribute chart types.
The following example creates a custom test called Test 1 and turns it on.
dt = Open( "$SAMPLE_DATA/Quality Control/Diameter.jmp" );
Variables( Subgroup( :DAY ), Y( :DIAMETER ) ),
Customize Tests( Test 1( 2, "1" ) ), // test number, n, label
Chart( Position( 1 ), Warnings( Test 1( 1 ) ) ), // turn Test 1 on
Chart( Position( 2 ) )
An alarm script alerts you when the data fail one or more tests. As an Alarm Script is invoked, the following variables are available, both in the issued script and in subsequent JSL scripts:
qc_col is the name of the column
qc_test is the test that failed
qc_sample is the sample number
qc_phase is the label of the phase during which the failure occurred
qc_firstRow is the first row in the sample
qc_lastRow is the last row in the sample
One way to generate automatic alarms is to make a script and store it with the data table as a data table script or column property named QC Alarm Script.
The following example automatically writes a message to the log whenever a test fails:
dt = Open( "$SAMPLE_DATA/Quality Control/Coating.jmp" );
obj = dt << Control Chart(
Sample Size( :Sample ),
KSigma( 3 ),
Chart Col( :Weight, XBar, R ),
Alarm Script(
Write(
"Out of Control for test ",
qc_test,
" in column ",
qc_col,
" in sample ",
qc_sample
obj << Test 1( 1 );
You can create a control chart with tests that are spoken aloud using the Speak function. Try the following example:
Alarm Script(
Speak(
Match( QC_Test,
1, "One point beyond Zone A",
QC_Test, 2,
"Nine points in a row in zone C or beyond", QC_Test,
5,
"Two out of three points in a row in Zone A
or beyond"
Ksigma( 3 ),
Chart Col( :Weight, Xbar( Test 1( 1 ), Test 2( 1 ), Test 5( 1 ) ), R )
You can have either of these scripts use any of the JSL alert commands, such as Speak, Write, or Mail.
A phase is a group of consecutive observations in the data table. For example, phases might correspond to time periods during which a new process is brought into production and then put through successive changes. Phases generate, for each level of the specified Phase variable, a new sigma, set of limits, zones, and resulting tests.
The following example illustrates setting the limits for the different phases of Diameter.jmp:
Phase( :Phase ),
Sample Size( :DAY ),
KSigma( 3 ),
Chart Col(
:DIAMETER,
XBar(
Phase Level(
"1",
Sigma( .29 ),
Avg( 4.3 ),
LCL( 3.99 ),
UCL( 4.72 )
Phase Level(
"2",
Sigma( .21 ),
Avg( 4.29 ),
LCL( 4 ),
UCL( 4.5 )
R( Phase Level( "1" ), Phase Level( "2" ) )
