Essential Graphing > Bubble Plots > Interact with the Bubble Plot > Control Animation for Dynamic Bubble Plots
Publication date: 02/06/2025
Use sliders and buttons to control the animation of dynamic bubble plots.
Figure 5.5 Animation Controls
Animation Controls
Table 5.1 Descriptions of the Animation Controls
Slider or Button
Description
<Time variable>
Controls which time values appear in the bubble plot. You manually drag the slider to see a progression of time. Click and drag on the time variable in the bubble plot to move its position.
Appears only if you specified a variable for Time.
Speed
Adjusts the speed of the animation.
Bubble Size
Adjusts the size of the bubbles. The bubbles maintain their relative size, but their absolute size can be adjusted.
Appears on all bubble plots.
Adjusts the time value by one unit and shows the previous time value.
Image shown hereImage shown here
Press Play to animate the bubble plot. Moves through all of the time values in order, and loops back to the beginning when the last time period is reached. Press Pause to stop the animation.
Adjusts the time value by one unit and shows the next time value.
Records the animation (Windows only).
Saves the animation as an animated GIF file (Windows only).
Split
Separates the bubble represented by the first, larger ID variable into its smaller constituent parts, which are defined by the second, smaller ID column. Select the bubble and click Split.
Appears only if you specified two ID variables.
Combine
Reverses the action of the Split button by recombining the smaller bubbles back into their original bubble. Select any of the smaller bubbles in the group and click Combine.
