Profilers > Contour Profiler > Contour Profiler Platform Options
Publication date: 07/24/2024
The Contour Profiler red triangle menu contains the following options:
Grid Density
Sets the density of the individual mesh plots or surface plots.
Graph Updating
Contains options to change the frequency of updates for the graph. (The difference might not be noticeable on a fast machine.) The following two options are available:
Per Mouse Move
Updates the graph continuously as you drag the mouse. This is the default setting.
Per Mouse Up
Updates the graph each time the mouse button is released.
Surface Plot
Shows or hides the individual mesh plots.
Contour Label
Shows or hides the name of the response variables as labels on the contour profiler. The label colors match the contour colors.
Contour Grid
Opens a window that enables you to specify contour intervals for each response column. When you click OK, a contour grid is drawn on the profiler. The grid is based on the specified intervals.
Remove Contour Grid
Removes the contour grid that is overlaid on the profiler.
Factor Settings
Provides a submenu of commands that enables you to save and transfer the Contour Profiler’s settings to other parts of JMP. See “Factor Settings”.
Simulator
Shows or hides the Simulator. See “Simulator”.
Up Dots
Shows or hides dots next to the contour lines. The dotted lines indicate the upward direction of the response values.
Set Contours to Current
Resets the contour lines to be where the current Y values are located. This means that all contour lines cross where the crosshairs are on the contour plot and the controls agree in the Y sliders.
Arrange X Controls Left
Rearranges the X and Y controls horizontally with the X controls on the left. Deselecting this option moves the X controls back to the top of the report.
Hide X Controls
Shows or hides the control settings for the factors.
Hide Y Controls
Shows or hides the control settings for the responses.
Multiple Contour Frames
Enables you to add one or more contour plots to the report that represent different combinations of factor settings. When you select this option, the Multiple Contour Frames window appears. Use the window to specify additional individual contour plots or a matrix of contour plots. You can specify a lower triangular, upper triangular, or full square matrix of contour frames. By default, the new contour plots are added to the current contour plots in the report. Click the Remove previous frames check box to remove the current contour plots and replace them with your new selections.
