Scripting Guide > Extending JMP > Communicate with SAS Cloud Analytic Services
Publication date: 02/06/2025
SAS Viya uses Cloud Analytic Services (CAS) code to perform calculations in the cloud. This feature provides a way for SAS Viya users and JMP users to collaborate. You can write CAS code in JMP to import data from and export data to the CAS server, convert CAS JSON text to a JMP data table, get a list of available CAS libraries, and more.
See the SAS CAS documentation at https://developer.sas.com/apis/cas/rest/current/apidoc.html for more information.
The SAS CAS documentation for CAS actions cover CASL, R, Python, Lua.
This section covers the following topics:
About CAS Actions
Connect to the CAS Server
Create and Submit a CAS Action
Create and Submit a CAS DATA Step Action
Create a New CAS Server
Import Data from the CAS Server
View a CAS Dataset
Get a List of Available CAS Libraries
Export Data from a Data Table to a CAS Server
Convert a CAS Table to a Data Table
Delete a CAS Table
Remove a CAS Table
Verify the CAS Server Connection
Get Details about the Current Connection
Disconnect from the CAS Server
Terminate All CAS Sessions
