Using JMP > Combine and Present Reports Using Dashboards
Publication date: 07/24/2024
Extend JMP
JMP is an extensible program that lets you broaden its functionality to create your own JMP components. With Dashboard Builder, you combine reports into a dashboard, a visual tool that lets you run and present reports on a regular basis. No JSL knowledge is required. Start with a template, click report components, insert graphs and pictures, and the dashboard is done. You can also combine windows outside Dashboard Builder to create dashboards.
Figure 12.1 A Dashboard with Two ReportsĀ
Contents
Combine JMP Reports by Creating a Dashboard
Example of Creating a Dashboard with Two JMP Reports
Using the Dashboard Builder
Red Triangle Options in the Dashboard Builder
Start with a Sample Dashboard
Edit a Dashboard
View a Running Dashboard
Example of Combining Windows to Create a Dashboard
Example of Adding Selection Filters to a Dashboard
Example of Creating a JMP Query Dashboard and Add-In
Example of Creating a Dashboard from Two Data Tables
