Multivariate Methods > K Means Cluster > K Means Report > Cluster Comparison Report
Publication date: 02/06/2025
In the K Means Cluster platform, the Cluster Comparison report gives fit statistics to compare the various models. The fit statistic is the Cubic Clustering Criterion (CCC). Larger values of CCC indicate better fit. The best fit is indicated with the designation Optimal CCC in a column called Best. See SAS Institute Inc. (1983). Constant columns are not included in the CCC calculation.
